T-1 vs. Hotchkis
Old Nov 20, 2004 | 12:54 PM
007Duc's Avatar
007Duc
Default T-1 vs. Hotchkis
I know this may have been covered before, but I tried a serch and couldn't find anything on it. which is better for handling on my 02 Z06. GM T-1 swaybars or the Hotchkis swaybars? Stock springs and shocks. What else would you suspension guys recomend I do to this cars suspension, short of a full coil over setup?
Old Nov 20, 2004 | 02:17 PM
007Duc's Avatar
007Duc
Looking at getting some sway bars here guys. A little help please.
Old Nov 20, 2004 | 02:22 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
For the price difference, I don't think you can beat the GM T-1 swaybars. What type of driving do you do mostly?
Old Nov 20, 2004 | 02:58 PM
Hool97's Avatar
Hool97
T-1 stiff sl harsh for the street, Hots less so.
Old Nov 20, 2004 | 03:21 PM
007Duc's Avatar
007Duc
I plan on lowering the car 1" and it is driven daily. I do like to drive agressively and occasionly take it out for a track day at my local road coarse.
Old Nov 20, 2004 | 03:23 PM
97C5ENVY's Avatar
97C5ENVY
Go with the T1's if you want the best in handling.
I have a coupe with Z06 springs, Bilstein Sport shocks, and T1 bars....and man let me tell you it corners like it's on rails.
Old Nov 20, 2004 | 03:41 PM
curtbriggs's Avatar
curtbriggs
Default GM T1 sway bars
Would someone please expand on the T1 bars. Does GM parts on line have them and listed under what? Is there another source? I would like to go to a heavier front bar on my Z51 99 Coupe.
Thanks, Curt
Old Nov 20, 2004 | 04:55 PM
ClarksZ06's Avatar
ClarksZ06
I have the T1's really enjoy them. I have had them long enough that they just seem normal. When I first put them on though the steering responce was hugely increased and the car stayed planted around corners much much better.
I ordered mine though my local chevy dealorship. I believe I paid $460 for both front and rear bars plus new bushings. Excellent improvement over stock for that much money.
Old Nov 20, 2004 | 05:02 PM
007Duc's Avatar
007Duc
Are you guys running polyurithane bushings, rubber bushings, or I've even heard teflon lined rubber bushings? Oh and what part #s do I ask for from chevy? $440 is cheaper than any of the online tuners usually around $699.
Old Nov 20, 2004 | 05:15 PM
ClarksZ06's Avatar
ClarksZ06
I got the teflon lined rubber bushings with mine. Sorry I can't help you with the part numbers, I just don't know.
Old Nov 20, 2004 | 05:20 PM
007Duc's Avatar
007Duc
Alright, this goes out to anyone. I need the part #s for the T1 sway bars and teflon lined bushings front and rear. Or at least whear I might find them. Thanks for all the help! I've made my desion to go with the T1s will my 02 Z06 shocks be alright for the time being untill I can afford something else, I'm probably going to have to get a clutch here pretty soon and have to watch the $$$
Old Nov 20, 2004 | 05:23 PM
ClarksZ06's Avatar
ClarksZ06
There would be no reason to change your Z06 shocks unless you just want to upgrade those also, or if you plan on dropping the car down more than the factory bolts will allow.
Old Nov 20, 2004 | 05:33 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
I put T1's on my car about 3 years ago and would never change them!!!! Actually going with coilover and poly bushings this winter for the ultimate ste-up.
Old Nov 20, 2004 | 10:41 PM
97C5ENVY's Avatar
97C5ENVY
The $699 i bet is for the bars, bushings, and endlinks.......where as the $440 i bet is just for the bars and bushings. The heim-joint adjustable endlinks cost ~$50 each.
Part numbers:
T1 Front Bar = 12480065
T1 Rear Bar = 12480066
T1 End Link = 12480067 (you will need 4 of these)
T1 Front Bushing = 12480068
T1 Rear Bushing = 12480069
FYI: I bought mine from PaceParts.com for $686.42 SHIPPED to my door (w/no TAX).
Old Nov 20, 2004 | 10:58 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Sway bars...
As others have said above, your car will corner flatter (better) with T1's.
The down side is a harsher ride. Just change the bars 1st without changing springs/shocks as stiff bars transfer force to the other wheels (your suspension is less independent) and give you the effect of stiffer springs and shocks.
You will probably like the way it corners, if it's not enough-you can do more!
I tried different bars (as I thought the T1's were too stiff) but whenever I had on a "lesser" bar my car felt insecure at higher speeds than when I had the T1's on!
Roy
Old Nov 20, 2004 | 11:14 PM
DirtyRed's Avatar
DirtyRed
I have the T1s on a 01 vert with F45 susp. The ride is not as harsh as you might think with such beefier bars. My car is a daily driver and I travel over various road surfaces. You'll just need to be careful going over bumps (as if you're not already ). The car corners very flat and stable. I highly recomend them. Got mine from LAPD. You can also get them at GMparts Direct.
BTW, the kit comes with bushings and endlinks. Adjust the endlinks all the way in for clearance and to avoid rattles.
Old Nov 20, 2004 | 11:46 PM
Laguna Blu's Avatar
Laguna Blu
Extremely happy with the Hotchkis setup which comes with the polyurethane bushings and heim links. Coupled with Bilstein sport shocks and base FE1 springs the ride is much improved yet not too harsh for city driving!!
To T-1 vs. Hotchkis
Old Nov 21, 2004 | 02:45 AM
7.0sc SuperVette
Default F45 suspension...
I had the F45 suspension on my '97 coupe. The light springs and the T1 bars made a delightful suspension!. However the weight of the blower/IC etc. with the soft springs dropped my front end so low that I almost had a double blowout from the tire wear due to the negative camber of the whole front end dropping. I put ZO6 springs in-that brought it back up, but combined with the Bilsteins the ride became a little harsh. That in itself doesn't bother me cause it handles so great.
Roy
Old Nov 21, 2004 | 09:23 AM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Zip Products has them with our own end links. I just created part numbers for them two weeks ago. We just installed them on a 2000 and the car rides great. The only issue is the solid endlinks. You can hear them when the window is down and you are going slow, they have a little rattle to them. Other than that is is a wonderful package.
Old Nov 21, 2004 | 11:28 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Default Considering the upgrade...
Have any of you guys ever driven with the Hotchkiss and then upgraded to the T1 bars after?? I would be curious to get some input from those individuals who had experienced both, from a ride quality standpoint as well as a handling standpoint. I currently run the Hotchkiss and think they handle pretty well, but would consider the stiffer T1's if it didn't come with a significant reduction in "ride quality" from my current set-up. Also, Ive heard that unless your on a smooth road, the stiffer T1's can actually hurt cornering ability as the wheels are less independant from one another...
Any thoughts?
