Harmonic Balancer Bad!
Old Nov 21, 2004 | 05:13 PM
C5dream's Avatar
C5dream
Default Harmonic Balancer Bad!
1999 C5
I just got my car last Saturday and already having a big problem.
During my drive today I started to notice a squealing during idle. I head home after hearing this to investigate. So I check the pulleys, alternator, etc. I pull off the A/C belt to try to eliminate those pulleys and A/C. After placing the main belt back on I started the car and it was still squealing. Back under the hood I notice the belt is halfway off the balancer. After closer inspection I notice the outer part of the harmonic balancer is back against the block.
During my drive I did get pretty high in RPMs. But didn’t hear or see any warning lights come on. Just when it idled it would make the squealing noise.
Car has 78k miles and it runs strong. Looking at the rubber material between the inner and outer parts of the balancer it looks a little hard. Is this a common problem with the LS1?
Looks like I will have something to do during my vacation next week. So where is the quickest place I can get a balancer? Also is the engine internally balanced? Would like to get an aftermarket balancer but don’t want to mess up the balancing.
Old Nov 21, 2004 | 06:39 PM
ditty22's Avatar
ditty22
Same thing happened to my 99 Get her fixed asap!!! laters
Old Nov 21, 2004 | 09:47 PM
C5dream's Avatar
C5dream
Already placed my order from Summit. Went ahead an bought the ASP underdrive pulley.
Now I have to take the old one out. Anything I need to know before I dig into it and anything else I will need to purchase besides the balancer?
Old Nov 21, 2004 | 10:25 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
I'm sure you know this but make sure to install a new crank bolt. The original is a one time only bolt.
Old Nov 22, 2004 | 01:16 AM
C5dream's Avatar
C5dream
According to Summit it comes with new bolt.
Started to remove the rack, so I could get to the balancer. Anyone have any tips on getting it out? Pulling it out the drivers side and its hitting the lower mounting boss. Do I need to drop the kmember to get it out? Just need 1/4 inch of clearance to get it out.
Old Nov 22, 2004 | 08:18 AM
IM QUIKR's Avatar
IM QUIKR
One our supporting tuners is A&A and this is done on all SC applications. A&A has the instructions for this procedure on his web site. Do yourself a favor and pin the new crank/balancer while you have it all apart. This way it won't spin on you ever again. You'll find this on the same website.
Old Nov 22, 2004 | 10:08 AM
waymirec's Avatar
waymirec
I had the same thing happen on my '99. Damned Harmonic Balancer ended up fallin off when I was on the highway. Scared the hell out of me too.
Old Nov 22, 2004 | 05:30 PM
jjcslynn's Avatar
jjcslynn
When I had to pull mine, I had to find a special puller. If I remember right, it needs 3 fingers. The one I used only had 2 and I had a bear of time getting it off. Installing was just as hard, and the old bolt isn't long enough to pull the new pulley on. I had to rig up a brass insert so I could tap it on until the OLD bolt caught the crank. Once in, I removed the old bolt and installed the new bolt.
To Harmonic Balancer Bad!
