intakes
Old Nov 22, 2004 | 07:41 PM
mad99c5's Avatar
mad99c5
Default intakes
what are some of the better names for cold air intakes?
Old Nov 22, 2004 | 07:49 PM
chanderson's Avatar
chanderson
Vararam ( www.vararam.com ) is what I have in my 2000 coupe. Even though they say its a bolt on system and you can do it in an afternoon, don't believe it. It is probably really easy if you have means to a lift because it involves getting it from the top and bottom. There are alot of others out there that I have done research on, but I think they're all about the same and you won't really feel the difference until your above 75+ mph and the difference is slight at that, just my opinion though.
Old Nov 22, 2004 | 07:56 PM
C5JONNY's Avatar
C5JONNY
Vararam is the best one performance wise, My trap speeds in the 1/4 went up anywhere from 3-5mph.
Old Nov 22, 2004 | 08:04 PM
pdd000's Avatar
pdd000
Originally Posted by C5JONNY
Vararam is the best one performance wise, .
Old Nov 22, 2004 | 09:29 PM
noel48's Avatar
noel48
St. Jude Donor '14
Vararam,but don't try the installation at home
Old Nov 22, 2004 | 10:22 PM
drdoc22's Avatar
drdoc22
Default Blackwing
It was easy to install. Not sure how much if any it added in terms of HP's.
Anyway - if it's simplicity to install it took 10 minutes.
I am not a mechanic - but it was really simple.
DOC
Old Nov 22, 2004 | 11:06 PM
BlackMagicC5's Avatar
BlackMagicC5
Old Nov 23, 2004 | 07:50 AM
Casem1's Avatar
Casem1
I bought a Halltech Stinger and it appears to be a well made intake system.
Old Nov 23, 2004 | 08:24 AM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Hurricane.....at WCC
Old Nov 23, 2004 | 10:04 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Cold Air = Halltech TRAP
Old Nov 24, 2004 | 05:33 PM
FallenWhun's Avatar
FallenWhun
Does the vararam pass the visual for emissions testing? I would imagine that it would be a PITA to keep switching to stock for testing.
Old Nov 24, 2004 | 05:51 PM
hightest's Avatar
hightest
I went with the Blackwing. Not as much horsepower gains as the vararam, but it looked like a better filtering set-up and sat higher from the road (less chance of water ingestion). The blackwing also comes with a filter minder (lets you know when to clean the filter.
Air Intake set-ups, just like an exhaust is all a matter of preference.
Old Nov 24, 2004 | 06:03 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
blackwing!
To intakes
