Fuel injector question
Old Nov 23, 2004 | 11:14 AM
Laguna Blu's Avatar
Laguna Blu
Default Fuel injector question
Is it necessary to upgrade the stock injectors on my '99 to handle upper end mods? The mods are listed in my sig. I have not had any fuel related problems but I'm not sure if I need 30lb injectors or if the stock ones are suitable. Really if there is no extra HP gained from the mod I don't feel it to be worth it. The car recently dynoed at 400 RWHP with the 390's. Any opinions?
Old Nov 23, 2004 | 01:27 PM
Laguna Blu's Avatar
Laguna Blu
Anyone running aftermarket injectors?
Old Nov 23, 2004 | 02:44 PM
see5's Avatar
see5
Do you have 26 or 28# injectors? If your tune achieved desired A/F ratios you are probably ok. With 26#ers you are probably in a high duty cycle area which is not the best. >90% is undesirable.
Old Nov 23, 2004 | 02:52 PM
Laguna Blu's Avatar
Laguna Blu
I assume that I have the 26# injectors since it is a '99. I was advised that the injectors should be o.k. with my mods and that changing them will not provide any extra oomph. If it is not supercharged, run with nitrous or a big cube motor then it is not necessary to change. We'll see.
To Fuel injector question
