Stubborn Rotors
Old Nov 25, 2004 | 01:57 PM
chris2's Avatar
chris2
Default Stubborn Rotors
I have one stubborn rotor that i can't seem to get off any suggestions.
Old Nov 25, 2004 | 02:08 PM
Dave1998's Avatar
Dave1998
And to Think yesterday I was reading how they just fall off !
Sorry to hear
Old Nov 25, 2004 | 02:25 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
spin it while tapping with a hammer...rubber mallet if you have it....also spraying liqid wrench or similar product will help....BTW is this a rear rotor?? do you have the parking brake set??
Old Nov 25, 2004 | 02:36 PM
Ls1Rat's Avatar
Ls1Rat
front or rear ?
Old Nov 25, 2004 | 02:37 PM
chris2's Avatar
chris2
the rotor is the rear driver side the e-brake is not on. I have tried the other suggestions you made but to no avail.
Old Nov 25, 2004 | 02:50 PM
Ls1Rat's Avatar
Ls1Rat
does the rotor wiggle or is it tight ?
If it wiggles , try manually backing off the e brake adjusters.
If it's tight, check for corrosion.
Old Nov 25, 2004 | 02:52 PM
pewter99's Avatar
pewter99
get a bigger hammer serious dude..it should come off just keep banging away..no pun intended..I can't believe its that bad..I only had one that was kinda tough...come to think of it ...it was the same one....just keep spinning and banging...
Old Nov 25, 2004 | 02:55 PM
Oyishdog's Avatar
Oyishdog
Big rubber mallet, and smack it HARD...mine were that way and took alot of force to come off.
other thought, which i tried, take 2 pieces of 2x4, place one on the back of the rotor, one on the front covered the wheel studs...then take a c-clamp and tighten it down....i found that useful as well.
now that i track the car, i change rotors out quite often, no time for serious rust, so they come right off.
Old Nov 25, 2004 | 03:15 PM
SilverBulletZ06's Avatar
SilverBulletZ06
Blowtorch then a few hits with a rubber mallet. It's probably just a bit rust-welded on. Next time get coated rotors.
Old Nov 25, 2004 | 03:19 PM
chris2's Avatar
chris2
i appreciate everybody chiming in, but still no luck i looked at the e-brake adjust . I belive that was what you were refering to at the bottom of the rotor on the inside i disconnected the spring and still no luck been banging this thing like crazy but it just won't come off.
Old Nov 25, 2004 | 03:26 PM
Ls1Rat's Avatar
Ls1Rat
Inside the rotor there is a star adjuster that turns to adjust the brake. this needs to be backed off. Use a screwdriver thru the hole and turn it until it loosens up. I can't remember which way but you'll figure it out. The adjuster is in the bottom of the backing plate.
I'm assuming it wiggles.
Old Nov 25, 2004 | 03:31 PM
chris2's Avatar
chris2
It dosen't wiggle. so that must not be it. i'm just exhausting all options.
Old Nov 25, 2004 | 04:10 PM
Ls1Rat's Avatar
Ls1Rat
gotta be corrosion then , liquid wrench the studs and hub and then bang away
Old Nov 25, 2004 | 04:21 PM
pewter99's Avatar
pewter99
this has got to be the longest "how do I remove a stuck rotor" thread ever.....damn
Old Nov 25, 2004 | 04:25 PM
Ls1Rat's Avatar
Ls1Rat
well , the poor guy is " stuck "
Old Nov 25, 2004 | 05:23 PM
chris2's Avatar
chris2
Finally after lots of liquid wrench. the rubber mallot and torch worked like a charm. thanks everyone for chiming in.
Old Nov 25, 2004 | 05:52 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
For next time... I saw this method posted by Mike Mercury:
To Stubborn Rotors
Old Nov 25, 2004 | 06:06 PM
pewter99's Avatar
pewter99
Old Nov 25, 2004 | 08:51 PM
RoHo's Avatar
RoHo
I went through the same damm thing a week after I ajusted by e brake, if you disconnect the e brake cable at the rear backing plate and pull off the little rubber dust cover off the arm this should give you access to the small black plastic e brake shoe adjuster, back it off and the rotor should come off
Old Nov 25, 2004 | 09:45 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Rust usually forms around the locator boss on the rear hub.. it's a metal to metal surface where water turn the hub to rust// a shot of Kruel or wd 40 will lossen this area.. also a 3 lb. brass hammer will do the trick.
