My thoughts on thread locking...
Old Nov 25, 2004 | 06:51 PM
Kale's Avatar
Kale
Default My thoughts on thread locking...
I can't find stuff that works well enough to keep the nuts on my valve covers. I've used loctite blue, but they still come loose.
Old Nov 25, 2004 | 06:53 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
heli arc em
Beaz's Avatar
Beaz
Edit: Nvm I thought this was OT :o
Old Nov 25, 2004 | 06:54 PM
Kale's Avatar
Kale
c5 tech? I got moved to c5 tech? How inappropriate. I'm not asking how to put painted plastic pieces on my engine, I'm talking about trying to hold down actual parts of the engine.
Old Nov 25, 2004 | 07:12 PM
bogus's Avatar
bogus
bada-bing, bada-boom. Nice cut.
Check Locktite red.
Old Nov 25, 2004 | 07:14 PM
Kale's Avatar
Kale
Check Locktite red.
Will do. Thanks. No more seepy oil smell! Some day I'll actually change the gaskets... NAH.
Old Nov 25, 2004 | 07:55 PM
HalM's Avatar
HalM
Loctite of any kind needs a clean surface....be sure you put the time in to make sure the threads are clean...
Old Nov 25, 2004 | 08:04 PM
RoHo's Avatar
RoHo
The red has more holding or locking power, give the red a try
Old Nov 25, 2004 | 08:19 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Check Locktite red.
Old Nov 25, 2004 | 08:25 PM
curtbriggs's Avatar
curtbriggs
I believe your problem is oil on the threads. Throw your nuts in a can of degreaser.
Use lacquer thinner or a similar degreaser on both parts and #240 blue loctite before assembly or #290 after assembly.
Old Nov 25, 2004 | 08:34 PM
Kale's Avatar
Kale
Oh, I see. Yes, they are quite dirty. I'll be sure to degrease them. Thanks.
Old Nov 25, 2004 | 08:39 PM
gojo's Avatar
gojo
If you get the surfaces clean, do not use loctite Red or the bolts will need to be heated to loosen.
Old Nov 25, 2004 | 09:08 PM
bogus's Avatar
bogus
which equates to? Starting the engine!
Old Nov 25, 2004 | 11:15 PM
gojo's Avatar
gojo
How about a torch.
Old Nov 25, 2004 | 11:22 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
How about a torch.
...( gathering my composure) ...Yes.....some people don't understand high temp polymers -> 90* - 100*C won't cut it.
To My thoughts on thread locking...
