Lights and all that?
Old Nov 26, 2004 | 05:11 AM
DocAcumen's Avatar
DocAcumen
Default Lights and all that?
Let me start, by saying I have learned so much here in my short time!
Thank y'all for that!
Now, for my questions'....
1st) I have a 2000 FRC, it has the dreaded turn signal problem! They work most of the time, but, some of the time they don't? I have read enough that I found the, "Flasher Fix"? But what is the real fix, to get do away with this problem?
2nd) I have no back up lights? I have only looked into that, as far as checking one bulb, and it was fine. I can only guess that if one is OK it would work, no need for both bulbs being good? I have looked in the owners manual, and do not see any fuse for this? Just an umm? What was it called a micro relay? I guess it is possible that it could be the switch at the shifter too? So with all that said, where do I start to correct these problems?
TIA! for any help....
Old Nov 26, 2004 | 09:41 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Question #2 - a back up sensor in the tranny that turns on the back up lights. In an m6, if I recall correctly.
Old Nov 26, 2004 | 10:14 AM
Jack Behrle's Avatar
Jack Behrle
Default Back up lights out?
Genreally, the sensor that plugs into the transmission is at fault. Costs about $25 and available at most Chevy dealers. Takes about 5 minutes to replace one you are in the air. (My 99 FRC failed one after 60K)
Good luck!
To Lights and all that?
