Changing rotors at home - help?
Old Nov 26, 2004 | 12:08 PM
sdnet's Avatar
sdnet
Default Changing rotors at home - help?
Hi:
I would like to install AC Delco's rotor package on my '99 at home.
Are there any "gotchas"?
Could anyone help me out with the service manual text? I'd need front and rear.
Thanks!
Old Nov 26, 2004 | 12:15 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
The only difficult part is getting the caliper bolts off (you'll need a breaker bar, unless you're really big )... make sure you have some Loctite blue handy for re-assembly.
It's pretty straight forward.
Old Nov 26, 2004 | 12:18 PM
boatboatboat's Avatar
boatboatboat
be careful. I twisted a bolt off that holds the bracket in place to the hub. Actualy snapped off 1 inch INSIDE the bracket.
Turned out to be the project from hell for me. had to have the car towed to the dealer.
The service tech said i hadn't done anything wrong, that it was just one of those "things"......
YIKES!
Old Nov 26, 2004 | 12:20 PM
sdnet's Avatar
sdnet
Thanks. I'm only concerned about the technical details, like how tight I need to torque my front and rear bolts down, and any other information necessary that I might not have without the service manual.
Old Nov 26, 2004 | 02:15 PM
RoHo's Avatar
RoHo
Just remember that the rear rotor has to come straight off the E brake or it wants to bind, if you can't get them off go to the back side of the e brake backing plate and diconnect the e brake cable, reach up and pull the small black rubber dust cover off the cable arm, this will give you access to the small black plastic e brake shoe adjuster, back it off untill the rotors are loose.
Old Nov 26, 2004 | 02:29 PM
sdnet's Avatar
sdnet
Do I need to remove the caliper brace from the knuckle in order to remove the rotor?
If I don't have to remove the caliper brace, then all I would need to do is remove the caliper itself and slide the rotor off under the brace - correct?
I don't know if the rotor is too large, requiring me to remove the entire caliper brace.
Thanks.
Old Nov 26, 2004 | 04:38 PM
boatboatboat
You DO NEED to remove the bracket that holds them in place. Remember when you put the bolts back into place that they require 125 ft lbs of torque.
Old Nov 26, 2004 | 06:16 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
And it should be noted: Don't use a vacuum pump bleeder to bleed the system.
Wanna guess how I figured that out?
http://forums.corvetteforum.com/showthread.php?t=955341
To Changing rotors at home - help?
