Codes List
Old Nov 29, 2004 | 02:08 PM
pastorbrad's Avatar
pastorbrad
St. Jude 15 Year Donor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Default Codes List
Sorry for the dupe, anyone got the link to the DIC codes list? Thanks.
Getting an intermittent P1652 in the PCM (10) category. Absolutely no functional problems at all. Annoying and puzzling.
Old Nov 29, 2004 | 02:25 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
http://www.c5forum.com/ayc/dtcdic.php
Old Nov 29, 2004 | 02:31 PM
5 Liter Eater
St. Jude Donor '11
Looks like one or more of your electronic shocks is not responding to commanded controls.
From the service manual:
The PCM controls the Powertrain Induced Chassis Pitch by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the controlled component. The driver has a fault line which is monitored by the PCM. When the PCM commands a component ON, the voltage of the control circuit should be low (near 0 volts). When the PCM commands the control circuit to a component OFF, the voltage potential should be high (near battery voltage). If the fault detection circuit senses a voltage other than what the system expects, the fault line status changes causing the DTC to set.
The PCM receives an ignition voltage feed from the Electronic Suspension Control module on the Powertrain Induced Chassis Pitch circuit. The PCM grounds this circuit when the vehicle accelerates rapidly or brakes hard. When the chassis pitch input circuit goes low (about 0 volts), the ESC module commands all four shock absorber solenoids to a firm position. The PCM calculates the chassis pitch information based on the engine torque and the vehicle braking force.
Conditions for Setting the DTC:
The PCM detects that the commanded state of the driver and the actual state of the control circuit do not match.
The condition must exist for a minimum of 5.0 seconds.
Old Nov 29, 2004 | 03:28 PM
pastorbrad's Avatar
pastorbrad
Wow! Thank-you-kind-sir-he-said. Actually I have that one, there was another one with an entire printout list of all the codes by category?
I can't swear to it, but every appearance of this thing would seem to roughly coincide with at least some degree of road imperfection encounter (of which we have a lot in New England, to say the least). Maybe there's a bad shock or...?
Old Nov 30, 2004 | 01:01 AM
GrayC5's Avatar
GrayC5
Hey Brad!
Here's a site that shows the DTCs specific to each model year:
Computer Codes for 1981 to 2003 Corvettes
Hope this helps.
Old Nov 30, 2004 | 07:03 AM
pastorbrad's Avatar
pastorbrad
Thanks, Jim! Got any of those Plains blizzards yet?
Old Nov 30, 2004 | 08:01 PM
pastorbrad's Avatar
pastorbrad
Uh...wow. I'm not sure I follow that, but no matter - does this mean that one of the shocks is defective, or the black box controlling the F55, or...? I get this code once in every start/run cycle, no matter how short or far I'm driving. It appears to have no relation to road conditions, no relation to whether the system is set to Tour or Sport. Just once now it has shown as a C code as well as an H code when I shut off the car at the end of a drive. I've cleared the codes each time in order to make sure I'm not confusing episodes.
One technical thought - I have the Z06 Motorsports wheels w/ Pilot Sports in Z06 sizes in place of ths stock wheels and tires. Each wheel/tire combo must weigh more than the original. Would this increase in unsprung weight account for the problem? It ran fine with this new setup for months, though...
Old Dec 2, 2004 | 03:54 PM
pastorbrad's Avatar
pastorbrad
ttt
To Codes List
