Annoying Whistle!?
Old Dec 1, 2004 | 03:20 AM
abailey269's Avatar
abailey269
Default Annoying Whistle!?
At part throttle i get this annoying whistle. It is not terribly loud but is extremely annoying none the less. Its coming from the from the engine bay. Doesnt really seem to go up or down in scale according to rpms, just a steady whistle.
Any ideas what it is?
Old Dec 1, 2004 | 03:36 AM
BigBlue's Avatar
BigBlue
Check all the connections from your air filter to your throttle body. It sounds like an intake leak.
Old Dec 1, 2004 | 12:44 PM
IllinoisCorvette's Avatar
IllinoisCorvette
What year is your car?? Im almost certain there is a TSB on that noise.
Old Dec 1, 2004 | 01:21 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Does it only occur ~2500 RPM's under part throttle? Check this out...
http://www.corvetteforum.net/c5/c5tech/
Old Dec 2, 2004 | 01:49 AM
abailey269's Avatar
abailey269
Nice write up and thanks for the replys guys. I will check out to see if its only around 2500rmps. Funny thing is that the dealership just had the intake manifold off to replace the Oil Pressure sensor and i previously did not have the whistle. hmm.
Old Dec 2, 2004 | 08:34 AM
mowrey96's Avatar
mowrey96
I have the same problem with the FAST intake???
Old Dec 2, 2004 | 12:42 PM
Mark S.'s Avatar
Mark S.
Bill's response is correct...I have had the same whistle (around 2,200-2,400 RPMS) since new when the outside temps drop into the mid 40s...it's the intake plenum...lots of '01s experience this.
Old Dec 12, 2004 | 01:16 PM
RedC5's Avatar
RedC5
I have this on my '98....exactly, when the temp last night was about 30. I hate to hear it on the hwy.
Old Dec 12, 2004 | 05:32 PM
HIZVETT's Avatar
HIZVETT
I have the same problem. Just installed vararam so I probably caused it. Need to go check.
Old Dec 12, 2004 | 07:57 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I have the same sound. I whiched over to the LS6 manifold last year. I didnt notice it with the top down in the summer, but have noticed it in the last month or two with the top up. Ill live with it because it's not that bad. I thought there was a TSB on the noise and it was associted with a cracked intake manifold.
Old Dec 17, 2004 | 07:56 PM
jbduvall's Avatar
jbduvall
Default BRUCE &JANS Page
I had the same whisle on my 01 vert. It turned out to be the Alternator. The dealer replaced it under extended warenty. Now it is quiet as a church mouse.
To Annoying Whistle!?
