Had compression test and leak down done, these numbers good?
Old Dec 1, 2004 | 08:01 PM
IFLUBYU's Avatar
IFLUBYU
Default Had compression test and leak down done, these numbers good?
Just wanted to get an idea about the general health of the innards. I've been running it pretty hard since putting the cam and pulley in last winter. Engine has 56k miles on it now.
Cyl Comp Leakdown%
1 170 95
2 170 92
3 170 95
4 170 90
5 170 90
6 170 90
7 165 95
8 165 95
This was done while the engine was fairly cold. How's it look?
Old Dec 1, 2004 | 11:24 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Cyl Comp Leakdown%
1 170 95
2 170 92
3 170 95
4 170 90
5 170 90
6 170 90
7 165 95
8 165 95
I think you want to do the leakdown when the engine is hot/operating temps. That should maximize ring/cylinder sealing. Then you want no more than 10% leakdown ( so 90% would be fine). I would think yours would be significantly better when hot.
Maybe one of the Gurus will chime in?????
