Oil Pressure Spike
Old Dec 2, 2004 | 01:01 PM
daniel32rings's Avatar
daniel32rings
Default Oil Pressure Spike
I am running synthetic oil in my stock 98' - I have noticed on warm up, sometimes I get a spike in the pressue up to 80#. After everything warms up it doesn't seem to be a problem. I have the same reading on the guage and on the readout.
Any thoughts would be appreciated.
Dan
Old Dec 2, 2004 | 01:04 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Dan
80# is a lot.. most people that get reading that high have a bad sensor.. not sure if they can work part time but I would bet that is the problem
I have a ported oil pump in my car and the most I see is 50-60 on cold start up and then 50ish when all is warm..
Old Dec 2, 2004 | 01:08 PM
RandW's Avatar
RandW
I doubt it's the sensor, they're either good or bad. Don't know what would cause your problem, though. Filter?
Old Dec 2, 2004 | 01:21 PM
daniel32rings
I'm not thinking filter, it gets changed like every 1,000 mi. I'm due so I will switch it out.
thanks for your thoughts
Dan
To Oil Pressure Spike
