AIR pump removal
Old Dec 2, 2004 | 08:55 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default AIR pump removal
Hi folks,
Removing the AIR pump on my offroad Corvette. Some of the plumbing runs behind the motor. Does it just cross over from one side to the other, or does it feed into anything back there? Also, what's it held in place by? Seems kind of hard to pull out from one side.
Any tips on how to get the piping completely out from behind the motor?
Old Dec 2, 2004 | 09:03 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
It has a long black tube that goes to the driver side area, then it T's off and goes to the passenger side into the air pipe on the header.
How much do you want for it. I know somebody who needs one for a project.
Old Dec 3, 2004 | 03:57 AM
blackbelt's Avatar
blackbelt
it is bolted to the back of the driver side head. Kinda a pain in the butt to get to but not impossible. After you get that bolt out just pull it out.
Old Dec 3, 2004 | 09:49 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Do you know the size of the bolt? If I could slip a gear wrench in there with the proper size the job would be much easier...
Old Dec 3, 2004 | 10:07 AM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Default air tube
13mm head on bolt. The hole is slotted so you just have to loosen it.
To AIR pump removal
