Custom wheels and TPS fit.
Old Dec 4, 2004 | 08:45 PM
curtbriggs's Avatar
curtbriggs
Default Custom wheels and TPS fit.
I tried to install the Tire Pressure sensors on a set of Fikse 18" ARO wheels and the valve stems touch the edge of the center section. These are as new wheels off EBay built for a 99 C5. Fikse says their wheels are sensor ready. Even a regular valve stem is close. To make these wheels work, I'll have to mill about an 1/8" relief for the valve stem and socket clearance and remove a small amount of plastic from the sensor lip so it will set flat. Must be why I got "such a good deal" on them.
Anyone else have this issue with Fikse or other wheels?
Old Dec 7, 2004 | 09:47 PM
curtbriggs's Avatar
curtbriggs
Fikse says the wheels are TPM sensor ready, later sensors are smaller and fit better. I had to remove about an 1/4" from the lip of the sensor body to make the valve stem align and it's still a tight fit. I also had to machine a 1/8" spacer for each wheels valve stem so the sensor nut wouldn't bottom out. The wheels need more clearance as a socket won't fit and it's hard to keep from marring the wheel doing 1/4 turns with a wrench.
