What all is involved in forging a motor? Which parts need to be forged? I am about to install an A & A Procharger kit and I'm just looking down the road to see what is involved if I want to exceed 600 hp.
thanks. is eagle a good brand, not familiar with them.
Eagle is a good brand, there were some problems with clearance with the early Eagle forged cranks. However I believe these problems have been solved. But as mentioned above the stock LS1 crank is a good piece and you can go with forged rods, pistons & the stock crank.
Pistons, rods, and rod bolts are the main components that need to be replaced. Guys have run in the 8's with the stock crank.
Mark
OK guys, I gotta play the devils advocate here. Whats wrong with the rods?
Is it just because their PM? What is the actual strength difference? What is the compressive yield compared to steel, forging only buy's you 10% over cast at best in steel.
Has anyone ever failed a rod without breaking a bolt or seizing a piston?
