Just replaced stock wires with MSD's this weekend.
Smoothed out the idle.
Fit same as stock and you can even reuse the stock boot shields.
FYI, all eight plug wires are exactly the same length.
Do I need to reuse the stock boot shields? I got the impression from MSD that this wasn't necessary.
So there is no damage to the wire if the shields aren't in place? but, probably over a period of time, heat is unlikely to be a friend to the insulation on the wires?
The plugs I removed were really brown. Is this a result of low air/fuel ratio (too rich)? I noticed an amazing smoothing of the idle when I put this set of MSD wires and V copper plugs in.
