Underhood Light
Old Dec 6, 2004 | 07:22 PM
spdnman's Avatar
spdnman
Default Underhood Light
Can someone please tell me the Part Number for the UNDERHOOD LIGHT BULB?
The underhood light is not working. Tried changing the plug and made sure the harness near the front of the hood was connected to the hood light. Still will not work. Any suggestions? Fuses? Which fuses?
Thanks,
Adam
Old Dec 6, 2004 | 07:57 PM
RandW's Avatar
RandW
Pull connector apart, they get corroded sometimes. Check that first (as long as bulb is ok!!)
Old Dec 7, 2004 | 10:38 AM
BayouVette's Avatar
BayouVette
i have the same problem. never figured out what is was though..
Old Dec 7, 2004 | 11:44 AM
Automag928's Avatar
Automag928
Check the bulb, and the connector under the hood...good luck
Old Dec 7, 2004 | 12:02 PM
Shylor's Avatar
Shylor
Did it work before? Did you buy the car new or used?
Fast one's Avatar
Fast one
Plug the lamp cable directly into the battery using jumper wires; if the light doesn't work the tilt switch, bulb or hood wiring is bad. If it does work then the fuse could be bad.
Old Dec 7, 2004 | 12:09 PM
spdnman's Avatar
spdnman
Worked before. Owned car since new.
Old Dec 10, 2004 | 08:05 PM
spdnman's Avatar
spdnman
ttt
To Underhood Light
