code C1296
Old Dec 7, 2004 | 01:40 PM
kumar75150's Avatar
kumar75150
Default code C1296
can anyone tell me what this code is?
I cant find it on my list.
Old Dec 7, 2004 | 01:41 PM
kumar75150's Avatar
kumar75150
BTW, it keeps displaying to service active handling so I'm guessing it has something to do with that.
Old Dec 7, 2004 | 02:07 PM
Patches's Avatar
Patches
C1296 - Master Cylinder Sensor Circuit Open Or Shorted
Old Dec 7, 2004 | 04:19 PM
Richin Chicago's Avatar
Richin Chicago
Here is what I have on C1296:
The EBCM uses input from the Brake Pressure Sensor for more accurate control during an Active Handling event.
Conditions for Setting the DTC
DTC C1296 can be set anytime the ignition switch is in the ON position, and the signal voltage from the Brake Pressure Sensor is less than 0.20 volts or greater than 4.80 volts.
Action Taken When the DTC Sets
ABS and TCS remain enabled, Active Handling(TM) is disabled.
Indicators that turn on: Car Icon (TCS indicator)
Messages displayed on the DTC: Service Active HNDLG
Conditions for Clearing the DTC
Condition for DTC is no longer present and scan tool clear DTC function is used.
Fifty ignition cycles have passed with no DTCs detected.
Diagnostic Aids
It is very important that a thorough inspection of the wiring and connectors be performed. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis, causing part replacement with reappearance of the malfunction.
An intermittent malfunction can be caused by poor connections, broken insulation, or a wire that is broken inside the insulation.
If an intermittent malfunction exists refer to Intermittent and Poor Connections in Diagrams, Diagnostic Aids.
Old Dec 7, 2004 | 04:21 PM
kumar75150's Avatar
kumar75150
Thanks guys. It is prolly some wire. Will have to check and see.
I just had a new motor installed so my car was basically apart and then on the dyno.
I usually get traction codes after dynoing but this is the first time I cant clear the code.
To code C1296
