heads and compression ratio issues
answer this in the thread reply:
what type of heads you have
what is the compression ratio
what size cam
is it a daily driver
what type of octane and fuel do you use.
I think alot can be learned here from these issues
This combo is not too wild for 93 octane gas at sea level, I could run 24 to 26 degrees timing, no problem. Sea level and 91 gas... probably too much comression for that.
If I had to choose between adding compression and adding timing, I'd add the compression. It makes your engine more efficient, givng better part throttle response, better gas mileage, less emissions, and yes, more HP! The LSx heads are very good, they thrive on compression. Chevy seems to agree, the LS6 went to 10.6:1 and now the LS2 going to 11.1:1.
Here is the setup I'm currently installing:
AFR 205 heads milled .024 for 62cc chambers
Cometic .040 head gaskets
This combo will give 11:1 CR
I bought AFR's cam (part #6016) which is basically a CompCam XER 224/228 .581/.588 114+1.
According to others on LS1TECH, this is a very streetable and powerful combination. I hope so!
I use my car as a daily driver, except in bad weather (1996 Bronco), but I do tolerate less than BMW comfort...
Still no KR on my beast. LS1 edited and dyno tuned during the summer in S.Fl.and makes 423-417 RWHP in 85-95 degree weather with 99-100+ IAT's and tuned mild. It is sea level (but the air is full of water) and I run 93 octane with the fans and a 160 thermo to keep the coolant below 200 degrees. On the highway during the summer it never gets above 178.
I have thought of putting a little torco octane boost as insurance bringing it to 94 octane during the summer 90-100+ weather, but that would be just for making sure all my horses show up to play.
I do run one range colder NGK plugs and headers w/o the goofy factory cats.
I just know that when I step on the gas my smile is bigger. Oh yeah I run on 93 octane. It's not a daily driver but she is no garage queen either at just under 40k miles on my 01 Coupe
Miamidave, One day I hope to return to Florida in the next couple of years and not have to worry about the car pinging or Knock retard. Your poor summer weather conditions are ideal for a ping or a KR, and im glad to hear at 11.2:1 your not getting anything on 93 octane.
great info so far
I was shocked! Further info I also have the standard LS1 oil from the PCV in my intake (thanks GM you douchebags!) and plan on getting one of those catch cans for further added power insurance. But I figure that also reduces octane a tad as well-but still no pings
The 5.3l heads with the TR224 should put me right where I want to be at 400-410 RWHP. I only want to buy rear tires once a year
I believe your heads with stock gaskets will give you about 11.2 CR. Since your having them worked on they should CC them to be sure.
...well, handing out the cash to Chris
). I don't know if adding the Fast 90mm intake and NW 90mm TB will make any difference, other than making me wait just a bit longer for it to warm up.
