Torque Converter Lockup Switch
Old Dec 7, 2004 | 08:53 PM
spdnman's Avatar
spdnman
Default Torque Converter Lockup Switch
What does a Torque Converter Lockup Switch do? Why would I want to have this on the street? Strip? I am not sure what happens when the converter locks up. What happens when a converter is locked and unlocked when on a dyno? Thanks.
Old Dec 9, 2004 | 04:40 PM
spdnman's Avatar
spdnman
ttt
Old Dec 9, 2004 | 05:33 PM
enderz06's Avatar
enderz06
I would like to know too. Great question
Old Dec 9, 2004 | 05:47 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
It embarasses you if you don't know how to use it!!! Carmen put one in my car and forgot to tell me. I tripped it with my helmet without knowing it and the car stalled and would not stay on.
Basically you would use it at the strip only.
I forget all the specs but but when the converter "locks up" both sides are turning at the same rate so it is 100% efficient.
Your converter does this on its own now.
The manual switch does it on demand.
At the strip you flip it so that that you can run the converter at 100% and hopefully get a little better MPH and maybe ET.
I don't think it is making a big difference for me and I forget to switch it most of the time anyway.
Old Dec 9, 2004 | 06:39 PM
Mike Mercury's Avatar
Mike Mercury
well... not quite. On the C5, the torque converter is not mechanically locked. Instead, the line pressure is raised higher to eliminate most - but not all - slippage. You can have something like 100rpm of locked TC slippage before the PCM would report it as a problem.
Old Dec 9, 2004 | 06:48 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
For a dyno example, we had a procharged camaro on the dyno that pulled 461 unlocked and 507 locked
Old Dec 10, 2004 | 04:03 PM
Barry Hanna's Avatar
Barry Hanna
Do you know where I can get the switch and harness for my '04 C5?
Old Dec 22, 2004 | 01:11 AM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
To Torque Converter Lockup Switch
