Need Help With Wheel Offset And Tire Size
Old Dec 13, 2004 | 12:05 PM
99 vett babycar's Avatar
99 vett babycar
Default Need Help With Wheel Offset And Tire Size
I've got a set of OE Concepts Z06 18 x 9.5 65mm offset wheels. I'd like to use these up front on my C5 but the 65mm offset scares me a little.
Does anyone know if I can use these things in the front with 275 35 18 tires without any clearence prblems ?? If not those tires, what are the largest tires I could use. Thanks.
Old Dec 13, 2004 | 04:53 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
From what I've read here on the forum most go with 265 35 18.
Since the offset for the front is 56mm I'm not sure how much difference it will make with the 65mm.
