X pipe require welding?
Old Dec 14, 2004 | 03:02 PM
huckleberrydude's Avatar
huckleberrydude
Default X pipe require welding?
got my cat back on a month ago. now time for the x-pipe
install pics?
what's required
Old Dec 14, 2004 | 03:21 PM
Last C5's Avatar
Last C5
Jacking the car up so that if you set tires back down on blocks they are about 20" off the ground, a tubing cutter is nice but you can use a sawsall, new gaskets from GM (they are better than the ones that come with the x-pipe), a torque wrench to really get it right, and good measuring tape. The x-pipe doesn't get welded unless you want it to be. I didn't. Look for x-pipe threads in search, if I remember right somebody had a how to with pictures. Good Luck.
Old Dec 14, 2004 | 03:27 PM
allanlaw's Avatar
allanlaw
MagnaFlow X pipes come with real easy instructions - they tell you just where to cut the old pipes (different length for each side).
Old Dec 14, 2004 | 04:29 PM
FKING1's Avatar
FKING1
Bassani X here. Just held it up to the existing pipes, marked and cut. No welding.
Fred K.
Old Dec 14, 2004 | 07:12 PM
Autoworker's Avatar
Autoworker
I think I paid 20.00 for a pipe cutter at Advance auto. It's worth the money to get a nice, clean cut . I bought the Corsa x-pipe and it was a easy install with good instructions. Most manufacturers download install instructions from their website. Didn't weld mine either ...kit comes with wide torco clamps which you torque to 40 or so ft lbs.
To X pipe require welding?
