SS Brake Line question
Old Dec 14, 2004 | 07:05 PM
LV's Avatar
LV
Default SS Brake Line question
Just got a set of Goodridge Stainless Steel Braided Brake Lines, but they didn't come with any install instructions or nomenclature. After a lot of thread searches and such, I see terms like "AN connection" and "Banjoe Bolts". To be honset, I'm not sure I got these or anything like them in the kit (from LAPD). Did get copper washers and 4 box lug looking brass pieces with a threaded nipple and a hole through the box center.
Anyone help on the descriptions and/or know of any install instruction available?
Appreciate the help,
LV
Old Dec 14, 2004 | 08:10 PM
Richin Chicago's Avatar
Richin Chicago
LV
I don't think I have ever seen any real useful instructions for this install. It is very straightforward. You can see where everything goes just by looking at the existing rubber brake lines. Just make sure you use all new copper washers at the sealing points.
Old Dec 14, 2004 | 08:39 PM
leaftye's Avatar
leaftye
And the longer lines are for the rear brakes. Install the rear first so there's less to fix if you screw up.
Old Dec 14, 2004 | 08:42 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Be sure to keep lots of brake fluid in the plastic holding tank... otherwise you will be in for a very hard time when bleeding the brakes.
VR
Old Dec 14, 2004 | 10:46 PM
LV's Avatar
LV
Thanks for the quick replies.
Any thoughts on the AN connections or Banjoes?
Old Dec 15, 2004 | 08:27 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
If the brake lines have a round hole at one end with a bolt that fits through it, they're the banjo bolt type.
Word of advice - get some shrink tube and put it on the brake lines to insure you won't get any codes. Only downside is that they won't look shiny and "bling".
Old Dec 15, 2004 | 12:26 PM
Z_fox's Avatar
Z_fox
Not sure I understand the reason for codes being set. I know the lines are abrasive but how will covering them stop codes from being sent?
Old Dec 15, 2004 | 12:47 PM
RidgecrestC5's Avatar
RidgecrestC5
Use the Torque settings on the box, I believe it is 25 ft lbs, If you go by the Corvette Manuals you will break the banjo bolts.
Old Dec 15, 2004 | 01:03 PM
leaftye's Avatar
leaftye
A TSB came out saying GM thought static could cause codes. Wrapping it seems to help. I'm sure different climates affects the occurance of codes. I get shocked by everything here in Albuquerque, NM, so it'd probably affect me if I didn't wrap.
To SS Brake Line question
