'99 wheels on '04
Old Dec 15, 2004 | 09:19 AM
duosy's Avatar
duosy
Default '99 wheels on '04
Can the '99 wheels and sensors be used on a 2004 vette. I know the wheels are a direct fit but I'm not sure if the 2004 computer can read the sensors supplied with the '99 vette. Just want to save a few $$ by using the mounted snow tires from my '99 on the '04.
Old Dec 15, 2004 | 09:36 AM
Midwest Vette's Avatar
Midwest Vette
The 99 sensors will not work on the 04. They changed sensors in 01. The 99 sensors will work in 97 thru 00 & your 04 sensors will in 01 thru 04.
Old Dec 15, 2004 | 10:04 AM
wamara's Avatar
wamara
Cruise-In II Veteran
'99 sensors won't work on an '04. However, if you can live w/o the readout, and can either ignore or just hit "reset" when you get a message on your DIC, you don't need to fiddle with them - it won't hurt anything.
Old Dec 15, 2004 | 10:06 AM
USA-VET's Avatar
USA-VET
Old Dec 15, 2004 | 10:11 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
hmmm... 98 sensors will work with a 00 pressure receiver.
that receiver also is used for the key FOB.
so If I replace my pressure/FOB receiver with one out of a 00, then not only will my pressure sensors still function, but I will also be able to use the cheaper remotes that don't have a ind of thier own.
To '99 wheels on '04
