Tranny leaking
Old Dec 16, 2004 | 09:58 AM
C5JONNY's Avatar
C5JONNY
Default Tranny leaking
I recently had a shift kit installed on my a4, afterwards I noticed my tranny leaking on my driveway. Mainly when the car is running. I brought the car to my buddies shop yesterday, and the gasket on the pan was split. I had them install a new one, and went on my way. I get the car home yesterday, park it, and when I move it again theres a nice fresh little puddle on my driveway. Is there some kind of overflow relief on the trans, or is the gasket split again. what do you guys think?
Old Dec 16, 2004 | 05:16 PM
YO-EL's Avatar
YO-EL
ys, there is a vent.. if its overfilled it will blow off or drip thru it..
Old Dec 16, 2004 | 10:36 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Check to see if the rear trans seal is leaking...the sudden cold shrinks up the seal(old design) and allows it to leak. there is a newer seal avalible.. it often looks like the pan is leaking because it runs down the pan rail towards the front of the trans when parked.
To Tranny leaking
