gear swap
Old Dec 17, 2004 | 12:22 AM
jhanwell's Avatar
jhanwell
Default gear swap
Can someone tell me in numbers what going from a 2.73 to a 3.42 is like. I guess what I am asking is what is your rpm at 70mph with the 3.42? Also is a torque converter switch neccessary when you swap the gear? Thanks!
Old Dec 17, 2004 | 12:43 AM
Mitch C's Avatar
Mitch C
I had 3.42s in my car, you will be at 2150 RPM at 70 MPH with 3.42 gears.
You don't have to swap converters, but I would strongly recommend that you do install a high stall T/C when you install your gears. A high stall T/C and gears are the best bang for the buck mods on an A4. Good Luck!!
Old Dec 17, 2004 | 12:49 AM
jhanwell's Avatar
jhanwell
Default Thanks
Thanks Mitch. Any idea how much this should cost and where in chicago to get it done? I realize you are from florida, hopefully others have some ideas.
Old Dec 17, 2004 | 12:56 AM
1FUNVTT's Avatar
1FUNVTT
Default High stall TC
What will the High Stall TC do for you? How is this different from the stock TC? Would you install this on a 3.15 RE A4
Greg
03-50thAE - A4
Old Dec 17, 2004 | 01:33 AM
Mitch C's Avatar
Mitch C
I paid $500.00 labor to install my gears and T/C. I can't help you with a good shop in Chicago.
Old Dec 17, 2004 | 01:43 AM
Mitch C's Avatar
Mitch C
Greg
03-50thAE - A4
A high stall T/C allows your engine to instantly spool up higher in the power band where it is making a lot more power when you go WOT. The stock T/C stalls at 1600 RPM a 3000 stall T/C would stall at 3000. Your engine makes alot more power at 3000 RPM than it does at 1600 RPM.
Whether or not I would use 3.15 gears with a T/C depends on your plans for your car, and your T/C selection. I would use 3.15s with a small converter (2800-3200) with a high STR. I would want at least 3.42s if the T/C I selected was 3500 stall or greater.
Old Dec 17, 2004 | 01:52 AM
1FUNVTT's Avatar
1FUNVTT
a big thanks for the TC education. Guess I better study up somemore before doing any mod.
Thanks again!
Old Dec 17, 2004 | 02:32 AM
Cscokd's Avatar
Cscokd
I created a really cool excel file to calculate RPM vs tire size, gear ratio and even MN6, M12, and A4 transmissions...but I am not allowed to post attachments. Can someone do this for me? I'm sure it would be helpful. Thanks.
John
does anyone know how to get attachments privileges? Maybe I have to have more stars under my sig...
Old Dec 17, 2004 | 04:31 AM
blktie8's Avatar
blktie8
http://www.smokemup.com/auto_math/rear_end.php
Old Dec 17, 2004 | 05:01 AM
Utopia's Avatar
Utopia
Here's a good shop in Chicago. They did some work on my car.
http://www.ls1speed.com/
Old Dec 17, 2004 | 07:57 AM
Mitch C's Avatar
Mitch C
Thanks again!
Glad to help, checkput the Yank Converters web site you will find a ton of info about converters on that site.
To gear swap
