Alignment specs (coilovers)
Old Dec 17, 2004 | 02:20 AM
Paras's Avatar
Paras
Default Alignment specs (coilovers)
Hi, for those of your who have read/responded to my posts, you might know that I'm running runflats with my coilovers. The day has finally come to say good-bye to the runflats and install some non-runflats. I have the Avon Tech M500s sitting in the garage. I'll let everyone know how they feel once I get them on. The question for the moment is, do these alignment specs which I've pulled from doing a search on many previous threads look good for my Coupe which has DRM coilovers and Z06 sways? I may not be including all the settings but here's my guess. Oh, I'm getting my tires mounted and balanced/aligned at 4:00 tomorrow so if you can, please send me comments by then. Thanks in advance!
Front
Camber: 0.5 degree per side
Caster: 7-8 degrees per side
Toe In: Just slightly... maybe about .05 (I found that this helped the car not shoot for the edges)
Rear
Camber: 0.5-0.75 negative per side
Toe: Zero
Thrust Angle: Zero
