Oil Pressure 130PSI!!!!!
Old Dec 17, 2004 | 11:03 AM
mowrey96's Avatar
mowrey96
Default Oil Pressure 130PSI!!!!!
The gauge is pegged at 80 and the DIC is showing 130 PSI. The oil level appears appropriate. If the car is off for a few minutes and then started, the pressure starts in the low 120's, then shoots up to 130. Do I have a faulty gauge or another problem?
help!
Old Dec 17, 2004 | 11:06 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
It is the oil pressure sending unit which is located in back of the intake manifold. Lots of owners have this problem. I did. Try searching around, there are a couple very good DIY writeups on replacing the sensor.
Old Dec 17, 2004 | 12:04 PM
mowrey96's Avatar
mowrey96
Is it definite that the sending unit is the problem? Is it not possible to create 130 PSI? I would hate to drive it if it could create any damage.
thanks for the input...
Old Dec 17, 2004 | 12:22 PM
5 Liter Eater
St. Jude Donor '11
I know it's un-nerving but I can assure you it's the sensor though if you're unsure and have an alternate vehicle, park it. Do a search and when you see all the posts from other forum members may help ease your mind.
Old Dec 17, 2004 | 03:07 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Turn the ignition on but dont start the car and you will see oil pressure on the gage which means the sensor is bad,
Old Dec 17, 2004 | 03:30 PM
RCK1999's Avatar
RCK1999
R.I.P. - sensor!
Old Dec 17, 2004 | 05:30 PM
RoHo's Avatar
RoHo
Is your oil up to the full mark on your dip stick, if it's not it will make the gauge act goofy, my buddy's car was 3/4 quart low, filled it up and the gauge is OK. It's worth an oil check, if nothing happens I agree - sensor
To Oil Pressure 130PSI!!!!!
