C5 engine removal
Old Dec 17, 2004 | 02:42 PM
DSKRALL's Avatar
DSKRALL
Default C5 engine removal
I just received a copy of Will Handzel's book How to Build High Performance LS1/LS6 V-8s. Handzel shows the entire drivetrain being removed when serious engine work needs to be done. Excuse my ignorance, but is there any other way to remove the engine? Is there any way to remove the entire drivetrain without using a huge lift? I'm not contemplating the job, but I am curious about it.
Old Dec 17, 2004 | 02:44 PM
Jackal's Avatar
Jackal
You can do it without a lift, but it would be MUCH easier with one.
Old Dec 17, 2004 | 08:00 PM
Tree's Avatar
Tree
There's no problem removing the engine from the top with an engine hoist (long legs and boom advised) with the car on jack stands. I assume the book instructs you to put the car on a lift and remove it from the bottom, the way Chevrolet recommends.
Old Dec 17, 2004 | 11:01 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
You would be surprized how easy it is to remove the entire drivetrain. Thats probably why Chevrolet recommends doing it that way. Of course you can pull the motor from the top but I think it takes much less time to drop it out from the bottom. I have not tried taking it out through the top so I am not posotive on that. Kaley
Old Dec 18, 2004 | 09:22 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I read that book also and when I got to the part about removing the whole drivetrain I just IMHO you are creating a HUGE amount of extra work by removeing the entire drivetrain.
The engine will unbolt from the torque tube very easily and from there you can either remove it from the bottom or the top depending on how your shop is equipped.
Old Dec 18, 2004 | 09:26 AM
DSKRALL's Avatar
DSKRALL
Thanks for the good replies. Handzel's book appears to be very good, but it's too bad he didn't demonstrate the different ways that the engine can be removed.
Old Dec 18, 2004 | 10:02 AM
Mike Mercury's Avatar
Mike Mercury
some people can only do things like instructed to. Others that can go beyond "the book"- don't - simply because lawyers get involved with the publishing process.
Thank god there are people on the forum that can go beyond "the book".
Old Dec 19, 2004 | 11:11 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've had my motor out through the top using jack stands several times now. Takes three jacks (one under the front of the diff, one under the rear of the front cradle, and one under the front of the front cradle), but it can be done. Last time we swapped a motor, which was at the Runoffs in Sept after I lost the harmonic balancer (another story altogether), we swapped the motor out in 18 hours out the top, which is just about what Chevy lists for a motor swap. We had the added complexity of the oil cooler lines and having to flush them and the whole intake out as well.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To C5 engine removal
