can certain plugs cause spark knock?
Old Dec 17, 2004 | 04:03 PM
mlm's Avatar
mlm
Default can certain plugs cause spark knock?
I am running the bosch 4 tip (electrode) plugs, could these cause my spark knock? I am about to install headers, what type plugs should I change to?
Old Dec 17, 2004 | 04:08 PM
Avanti's Avatar
Avanti
All else being equal the issue is typically heat range of the plugs... too hot (not passing enough combustion heat to the heads) and igniting the mixture too soon.
All the best.
Old Dec 18, 2004 | 06:44 AM
mlm's Avatar
mlm
Default whats a good plug for ls1 with bolt ons?
Any suggestions for plugs I could try? Information and Experience needed. My ls1 is stock except for bolt ons. I have some spark knock at low and high rpms under heavy throttle.
Old Dec 18, 2004 | 07:24 AM
Patman's Avatar
Patman
Put in NGK TR55s at .050 gap and you'll love them. If you don't mind changing them more often, you could also go with the NGK TR6s, which are one step colder and will lessen the spark knock a bit more.
Old Dec 18, 2004 | 09:54 AM
Mike Mercury's Avatar
Mike Mercury
I had the Bosch +4's in my stock engine - and took thenm out only after 100 miles.
Went with the AC Delco Iridiums - and everything smooooothed out nicely
Old Dec 18, 2004 | 11:08 AM
mlm's Avatar
mlm
Default thanks for the info....very much!
very helpful, thanks.
To can certain plugs cause spark knock?
