Bedding the Brake pads/rotors? How important is this and what works best? When we take the car in to a dealer for brakes, does he bed the brakes? Just wondering.
Very unlikely. That would be a sign of quality service. They're better at dropping cars off lifts, over and under torqueing fasteners and scratching the paint. There are a few good dealerships out there, but they're few and far between.
Try a search in the C5 autocross section. There is a lot of good info there. Basically it goes like this, get up to 40mph and press the brakes hard enough not to lock them and slow to 5mph. do this 3 times. get up to 60mph and do the same (3 times). Get up to 90mph and do it all again(3X). You want them to heat up to 1000 degrees. Drive for 1/2 hour to cool brakes and let sit 24 hours(not just over night) Go out again and do it once more.
I just did day 1 and checked the wheels. Man is there a lot of black dust on the rims. It's going to be 15 degrees tomorrow so I probably can't get them up to temp no matter how hard I brake. It'll have to wait for warmer weather.
Try a search in the C5 autocross section. There is a lot of good info there. Basically it goes like this, get up to 40mph and press the brakes hard enough not to lock them and slow to 5mph. do this 3 times. get up to 60mph and do the same (3 times). Get up to 90mph and do it all again(3X). You want them to heat up to 1000 degrees. Drive for 1/2 hour to cool brakes and let sit 24 hours(not over night) Go out again and do it once more.
You need to break in the pads with the rotor.
however different pads have different break in procedure.
most of them recommend the one you describe but some pads ask for a different break in.
Normally it is described on or inside the box of the pads.
the outside temperature won't change a lot of the rotor temperature.
two weeks ago I went on track by 30 degrees.
the video showed the front rotors orange which is way over 1000 degrees F
