Good parts?
Old Dec 17, 2004 | 07:59 PM
StoCK's Avatar
StoCK
Default Good parts?
Here is my current part list:
1) Hurst short-throw shifter
2) Hallitech Stinger intake system
3) B&B Bullet cat-back
4) Dynatech long-tubes and x-pipe
5) MTI stage 2E heads
6) MTI camshaft
7) Hypertech 160 degree thermostat
8) Nitto 555 Extreme Performance tires
9) Dyno tune
Sound good? With these parts, I hope to make over 400 rwhp and run 11s in the 1/4.
I estimate I'll cost me around $6,000 total (parts, shipping, installation).
As usual, is there anything you would change, add, remove, etc.?
Old Dec 17, 2004 | 09:16 PM
ICULUKN-C5's Avatar
ICULUKN-C5
I have had good luck with B&M
Blackwing will get your the same HP and save your some $
I like Borla Stingers, but it probably doesnt matter much
What sze are these?
6) MTI camshaft
Need specs... go big or go home
I would try BFG Drag raidals or ET Streets. Nittos are a little too hard IMO
9) Dyno tune
You will eventually need a clutch, slave, and flywheel
Old Dec 18, 2004 | 12:38 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Probably an output shaft too with the Drag Radials.
To Good parts?
