SY3200 shifting problem
Old Dec 19, 2004 | 10:16 AM
Bling Bling's Avatar
Bling Bling
Default SY3200 shifting problem
I have a special Yank 3200 TC. Under normal accelaration when I get to 4th gear it shifts back down to 3rd then back to 4th. I have access to LS1 edit. Any ideas on what I could change? Thanks and Merry Christmas.
Old Dec 19, 2004 | 10:22 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Is it shifting between 3 and 4 or is it the TCC locking and unlocking?
Old Dec 19, 2004 | 07:12 PM
Bling Bling
Yes it locks in 4th, unlocks then locks back up again.
Old Dec 19, 2004 | 11:51 PM
ToplessTexan
If you like where your shifts are happening, you need to adjust your TCC apply and release tables. You may want to try either locking later or lowering release points (or perhaps both) at the speeds/TPS this is happening at. Assuming fluid level is correct.
Old Dec 20, 2004 | 05:07 PM
Bling Bling
Sounds good i'll try that. Thanks for your help
Old Dec 20, 2004 | 05:48 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
To SY3200 shifting problem
