door window gets caught on convert top
Old Dec 19, 2004 | 01:21 PM
stangboy11's Avatar
stangboy11
Default door window gets caught on convert top
Hi guys
Time to store the machine for the winter. What I noticed is that the top rear of the drivers side window gets caught on the top right corner off the convertible top when I close the door. But, if I shut the door by pushing on the window, it clears the top. It's beginning to damage the cloth top...I'm assuming the window needs to be adjusted and pushed in a little. This is a 1998 convertible. Is this a difficult task? Would anyone have any idea how to do it?
P.S. if it rains hard the top leaks a bit on the top front corner.
Elio
Old Dec 19, 2004 | 04:31 PM
PaceThis's Avatar
PaceThis
If you're a diy kind of guy...it's easy.
1st remove door panel. under door pull, pull removable 1/2" x 2" cover (pulls off). I think there are 1 or 2 torx bits in there...take them out and pop off the door panel.
There are (I think) 2 bolts, one on each side towards the top of the door that hold the glass in place (if the window is up, which is where it should be before you begin this task). I think they may be 10mm, but it's been a while...so use what fits.
Loosen each only slightly where you can pull the window around. Put it where you want it (test it a few times to get it right) and retighten the bolts. 10-15 minutes should do it, it's pretty easy. You want to get it as far up as possible to keep it from leaking, but it has to be down just enough to clear the top.
By the way, you want to buy something called a window valet, made by top down tech. It's about $150, but will let you control your windows remotely. In the summer, it will save a lot of time putting windows up and down. Using it this way will also save some rubbing on your top, which will save you money in the long run. Even adjusted properly, you'll probably rub the corners slightly...
Old Dec 19, 2004 | 05:26 PM
stangboy11's Avatar
stangboy11
Thankyou for your comments PaceThis
I also found this:
Window Tip-In Adjustment - Door
Tools Required
#6 Inverted TORX® Socket
Position the window fully up.
Remove the large access plug from under the front of the door.
Loosen the window regulator front channel mounting nut.
Remove the reflector from the trim panel
Loosen the jack screw jam nut.
Adjust tip in with the jack screw.
Turn the jack screw clockwise to tip the window outward.
Turn the jack screw counterclockwise to tip the window inward.
One turn of the screw equals approximately 1 N·m (0.04 in) change at the top of the window.
Tighten the jack screw jam nut.
Lower the window.
Tighten the window regulator channel front mounting nut.
Raise the window and check the alignment.
Install the access plug under the front of the door.
Install the reflector in the door trim panel.
I may give it a shot this winter. This petpeeve is starting to get on my nerves. I like that remote window opener idea. The only think that bugs me is that I don`t want to carry another remote around.
Old Dec 19, 2004 | 05:31 PM
stangboy11's Avatar
stangboy11
Default cool
you know what, I just ran the demo video....whooo that`s so cool. It uses all the factory accessories and the factory remote. Really nice idea!
Old Dec 19, 2004 | 11:08 PM
donnyonee's Avatar
donnyonee
what i found with the valet on my vert is that if i have the window cracked down a couple inches and raise it with the valet, it goes up and then down "BOTH WINDOWS" go down. now most of the time this is ok and another 3 clicks on the fob they both go up and stay, but what if its raining?
just a thought.
i also have the window catching problem, both, and i think i will try to lower the stop a fraction, not the tip in. anyone know how to stop the travel a fraction lower?
my pass window has a air leak on the back edge that id like to stop. its not enough for a water leak , just air and is kind of anoying, there was a post about adjusting the rubbers but i cant find it, does anyone have that post?
thanks, don
happy holidays!
Old Dec 19, 2004 | 11:21 PM
PaceThis's Avatar
PaceThis
The valet's directions tells you that it only works if they're all the way down...
Besides, if it's raining, your windows should be up when you get out of the car...no?
It's really easy to adjust the window, I'd start there.
Old Dec 20, 2004 | 12:02 AM
GrayC5's Avatar
GrayC5
Convertible care, adjustments, and tips
Old Dec 20, 2004 | 12:03 AM
donnyonee's Avatar
donnyonee
here in calif when it rains its still pretty warm and its common to have the window down just a smidge, thats where the problem is with the valet. i like it but it has its down side. get it ? that a joke, its down side.
i still need some stop travel adjustment if anyone knows of this.?
Old Dec 20, 2004 | 12:17 AM
Laguna Blu's Avatar
Laguna Blu
Alignment issue from the factory. I had to have the door adjusted in order to remedy the exact same problem in the exact same spot.
Old Dec 20, 2004 | 12:48 AM
donnyonee's Avatar
donnyonee
grayc5-
excellent! thank you!
Old Dec 20, 2004 | 01:11 PM
Skyguy^^'s Avatar
Skyguy^^
No need to carry around another remote, as you use the stock FOB to actuate the windows.
Old Dec 20, 2004 | 10:31 PM
curtbriggs's Avatar
curtbriggs
Default Adjust your window up stops
I think your problem is the window upstops were never adjusted. There are two, a front and a rear, located on the regulator just below the window clamps. These clamps hold the glass in place.
See my thread: Electric windows inop, how to fix.
Old Dec 20, 2004 | 10:34 PM
donnyonee's Avatar
donnyonee
do youn have a link to the thread?
thanks, don
Old Dec 21, 2004 | 02:01 PM
TorchRedRaider's Avatar
TorchRedRaider
I also used the Tip found below and I have recommended it several times before. Read the following link for adjusting the top.
http://www.c5forum.com/cgi-bin/ultim...ic/1/2213.html
5th pic, not the yellow arrow, but the set screw and jam nut below it.
What you want to adjust are the tension and set screws on either side of the top frame where it attaches to the body. This will cause the top to have a tighter strech and lift the edge just a bit for the window to clear properly. Still catches on occasion, but that is probably due to relative humidity and the fabric relaxing a bit.
With the seasonal change I just had to re-adjust the top last week, 12/15/04.
It fixed my issue.
I have also played with the tip in, but for some reason, that adjustment made very little change, as I suspect my windows were already at max tip in.
Here is a previous thread
http://forums.corvetteforum.com/show...ght=adjustment
Old Dec 21, 2004 | 06:42 PM
curtbriggs's Avatar
curtbriggs
http://forums.corvetteforum.com/showthread.php?t=962249
To door window gets caught on convert top
