zip tie mod, what is it?
Old Dec 19, 2004 | 09:39 PM
figovette's Avatar
figovette
Default zip tie mod, what is it?
can some one tell me what the zip tie mod is that people mention on the forum. thanx
Old Dec 19, 2004 | 09:52 PM
RWhite's Avatar
RWhite
http://forums.corvetteforum.com/show...ht=zip+tie+mod
Do the search and you will find many posts alluding to this simple mod.
Old Dec 19, 2004 | 10:06 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do not do it, its not worth the risk for .5 hp
Old Dec 20, 2004 | 12:56 AM
BlackMagicC5's Avatar
BlackMagicC5
Its when you take the cover off your intake, and zip tie the filter to the frame that the filter sits in. This leaves the filter exposed to the air. You might pick up a couple of extra horsepower for free. I doubt theres any risk. I just think it looks ugly.
Old Dec 20, 2004 | 07:24 AM
warren s's Avatar
warren s
Check out my website, click on simple C5 mods.
Old Dec 20, 2004 | 12:47 PM
figovette's Avatar
figovette
Default thanx dudes
rwwhite, screw991le, blownfrc and warrens thanx 4 the replies
Old Dec 20, 2004 | 02:46 PM
RABVET427's Avatar
RABVET427
I totally agree that it looks ugly and simply inconsistant with a 40-50K machine. Another option is to purchase the modified factory cover from Eckler for $69.99 (P/N 37053) which has a very large cut out to expose the filter and yet retain it without requiring the zip ties, Add the K&N replacement filter and it will look professional and give you superior air flow over oem with at least a 5 RWHP gain. The only issue then, is water intake assuming you drive you car in that kind of condition. If that is the case maybe consider the Mid America modified cover # 612-571 @$75.99 with a somewhat smaller opening, but again there may be a water concern (only somewhat less). I recommend getting additional advise from the more experienced members to help you decide. I don't mean to be critical of the zip tie method becuse it is VERY impressive and cost effectively nothing, it's just a looks issue for some of us.
Old Dec 20, 2004 | 05:45 PM
RCK1999's Avatar
RCK1999
M-I-C-K-E-Y M-O-U-S-E!!!!!
Old Dec 21, 2004 | 12:09 AM
SoldmyWS64AC5's Avatar
SoldmyWS64AC5
Takes 10 minutes to do, doesn't really look THAT bad unless you have a show car. Its a good bandaid until you wanna dish out the money for an aftermarket setup. I had a AIRraid filter on my Z28 so I washed it and put it on the vette with the Zip tie. If I had to buy the K&N filter for it I'd probably spend the extra 140 and buy the stinger that is on a GP right now. I still might do that...
Old Dec 21, 2004 | 02:04 AM
Shylor's Avatar
Shylor
And the risk is?
Old Dec 21, 2004 | 03:03 PM
TopCat's Avatar
TopCat
Originally Posted by Shylor
And the risk is?
The risk is that the filter doesn't seat well against the filter box. There's ways around it, but the effort would be better spent elsewhere....like making a PCV filter, cleaning out the carbon with top end cleaner, replacing the spark plugs, etc.
Also, regarding the K&N mentioned earlier, an individual did an independent test on his Miata and has shown that the K&N doesn't filter as well as a good paper filter does. He also found that the pressure drop difference between a K&N and a paper filter isn't that great, i.e. the HP gains can't be that great. Check it out at www.bobistheoilguy.com. Interesting read at least.
My Donaldson filter may be just as bad as the K&N, but it IS a different type of filter material and the company makes all sorts of air filtration products. Far more than K&N. My advice.....get a modified airbox cover with a paper filter or, better yet, a quality cold air intake, Blackwing being the minimum based on surface area, design, company experience, and ease of installation. Just MHO.
To zip tie mod, what is it?
