Body Control Module Question
Old Dec 23, 2004 | 02:23 PM
cazorp's Avatar
cazorp
Default Body Control Module Question
Has anyone of you had to replace the Body Control Module on your C-5. I believe I may be having to do that soon. Can you tell me the kinds of things that happen when one goes bad? On my 2001 coupe, I get all kinds of warning messages on the DIC and all the lights come on, such as the Active Handling Light, ABS light, etc. I also get messages like, service engine soon; reduced power; check tire monitoring sensors; low fuel; etc.
Also, my windows quit operating; as well as the power door locks and the radio quits working.
I can turn off the engine, and it may clear everything and then act like nothing is going on for a day or two, and then the same things happen again.
I have replaced the battery and had all of the 9 grounding connectors checked and tightened on the car. My mechanic, who is not a dealership, advises me to take it to the dealership as he says the BCM is warranted for up to 8 years.
Does anyone have any expertise in this area? Your help is appreciated.
Old Dec 23, 2004 | 02:25 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
http://forums.corvetteforum.com/showthread.php?t=975152
Old Dec 23, 2004 | 10:33 PM
HurricaneZ's Avatar
HurricaneZ
A failing BCM can cause all kinds of weird havak. I see this on a daily basis. Sometimes its a always empty fuel guage, other times nothing will work as you described. The BCM is like the router once its confused no telling what can happen. Good Luck.
To Body Control Module Question
