Riddle me this.....
P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
I just replaced both o2 sensors last week, however I used Bosch Sensors. The car seems to run rich all the time. I know i need to take it to Mike Norris, but he's out of the shop this week, and my drive train seems destined to keep me out of his shop. <two breaks in two monthes>
What do you folks suggest i check tomorrow? I'm going to clean the Air Filter and just make sure everything intake side is ok, in hopes to find otu why i'm rich. Is there a way to clean off a MAF?
Thank you very much guys, and i hope everybody is having a wonderfull holiday!
Mike
You need to check the front O2 sensor on the right bank
Thank you for the responces.
Some guidelines to go by from the manual when checking for cutouts/misses.
General Prelim.
· Check the PCM grounds for being clean, tight and in their proper locations. Refer to PCM wiring diagrams .
· Remove the air filter element and check for dirt or for being restricted. Replace as necessary.
Fuel System
· Perform the injector balance test.
· Check for a low fuel pressure condition.
· Check for a restricted fuel filter.
· Check for a contaminated fuel condition.
· Check items which can cause an engine to run rich (long term fuel trim near -13%). For a rich condition, refer to DTC P0132 HO2S Circuit High Voltage Bank 1 Sensor 1 and DTC P0152 HO2S Circuit High Voltage Bank 2 Sensor 1 .
· Check items that can cause an engine to run lean (long term fuel trim near 23%). For a Lean condition, refer to DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1 and DTC P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1 .
Sensor System
· Use a scan tool in order to monitor the KS system for excessive spark retard activity.
Ignition System
· Wet down the secondary ignition system with water from a spray bottle. Wetting down the secondary ignition system may help locate damaged or deteriorated components. Look/listen for arcing or misfiring as you apply water.
· Check for proper ignition voltage output with spark tester J 26792 .
· Remove the spark plugs and check for the following: o Correct heat range.
o Wet plugs
o Cracks
o Wear
o Improper gap
o Burned electrodes
o Heavy deposits
· An improper spark plug gap will cause a driveability problem. Do the spark plug gapping using a wire gauge gap tool. Determine the cause of the fouling before replacing the spark plugs if the spark plugs are gas or oil fouled. Refer to DTC P0172 Fuel Trim System Rich Bank 1 and DTC P0175 Fuel Trim System Rich Bank 2 for diagnosis of the rich condition or Engine/Engine Mechanical for diagnosis of the oil fouling condition.
· Visually/Physically inspect the Secondary ignition for the following:
o Ignition wires for cross firing
o Ignition wires arcing to ground
o Ignition wires for proper routing
o Ignition coils for cracks or carbon tracking
Engine - Mechanical
· Check engine mechanical for the following:
o Check compression
o Sticking or leaking valves
o Worn camshaft lobes
o Valve timing
o Bent push rods
o Worn rocker arms
o Broken valve springs
o Excessive oil in combustion chamber-Leaking valve seals
o Low cylinder compression
· For incorrect basic engine parts. Inspect the following:
o Camshaft
o Cylinder heads
o Pistons, etc.
Exhaust System
· Check exhaust system for possible restrictions. Check for the following:
o Inspect the exhaust system for damaged or collapsed pipes.
o Inspect the exhaust manifold for a collapsed inner wall.
o Inspect the mufflers for heat distress or possible internal failure.
General Prelim.
Fuel System
Sensor System
Ignition System
o Wet plugs
o Cracks
o Wear
o Improper gap
o Burned electrodes
o Heavy deposits
Engine - Mechanical
o Check compression
o Valve timing
o Bent push rods
o Worn rocker arms
o Camshaft
o Cylinder heads
o Pistons, etc.
Exhaust System
