power seat help
Old Dec 27, 2004 | 01:01 PM
woody1243's Avatar
woody1243
Default power seat help
I have a 99 vert with a power drivers seat with memory seat problem that keeps draining the battery. It seems that the lumber support motor seems to run on and off draining the battery. It does this about every 30 seconds. The two small switches that control lumber and not sure what the other one does do not seem to do anything at this point. I have pulled the fuses to try to reset the seat control module. No difference. Any help or a schematic of the drivers power seat circuit would be a help along with how to get the power seat switches out without breaking the plastic mounting. I don't want to force anything and break it.
Thanks...
Old Dec 27, 2004 | 04:26 PM
mcmoore's Avatar
mcmoore
I had the same problem with my 99 vert. I ended up buying a new power seat switch assembly and that cured the problem. Purchased from GM Parts direct for under $50.00.
