98 m6 tranny leak
Old Dec 27, 2004 | 06:10 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default 98 m6 tranny leak
leaking tranny fluid, is this common? there is a large o-ring between the diff and tranny right? car has 110k on the clock
Old Dec 27, 2004 | 06:36 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Leak'n tranny
________________________________________ ____________________
[connecticut]leaking tranny fluid, is this common? there is a large o-ring between the diff and tranny right? car has 110k on the clock.
I don't think it's too common, but you do have 110k on everything. Nice going by the way. If the leak is only a couple of drops on the floor each week, you might want to learn to live with it. Just check it when you change your oil. The O-Ring I would guess is about $3.60. The labor to change the O-Ring is probably in the $400.00 ballpark.
Old Dec 27, 2004 | 06:41 PM
SteveDoten's Avatar
SteveDoten
Default lift avail.
my uncle just installed a lift in his garage , what's the procedure for the o-ring, i fix aircraft for a living and working on the vette is one of my addictions , nice car btw
Old Dec 27, 2004 | 06:59 PM
6SPD98's Avatar
6SPD98
Default "O-Ring"
[connecticut]my uncle just installed a lift in his garage , what's the procedure for the o-ring, i fix aircraft for a living and working on the vette is one of my addictions , nice car btw.
You are going to love to work on this car. The lift will make all the difference in the world. I give credit to everyone out there that has done this on jack stands.
I don't have the procedure, but, there are a few guys out there that do. I'm sure someone will be in touch soon.
Have a Happy and a Safe New Year
To 98 m6 tranny leak
