Will GM Limited Slip Addivite........
Old Dec 29, 2004 | 04:23 PM
Falcon's Avatar
Falcon
Default Will GM Limited Slip Addivite........
mix readily with Mobile1 differential lube?
Is it necessary with Mobile 1 to keep the diff from chattering?
TIA.
Old Dec 29, 2004 | 04:59 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes and Yes
It is need with any fluid and yes it will mix with a synth. It is a "friction type oil"
Plus for 6 bucks why chance it.
Old Dec 29, 2004 | 05:42 PM
Falcon's Avatar
Falcon
Thanks!
I already have the additive, I just didn't want to do something that might make the Mobile 1 ineffective.
To Will GM Limited Slip Addivite........
