Reverse Lights
Old Jan 2, 2005 | 12:26 AM
NavyBlue99's Avatar
NavyBlue99
Default Reverse Lights
I just finished my heads and cam install and now my reverse lights do not come on when you put the shifter in reverse. The lights flash when i hit the unlock button so they obviously work but for some reason they do not engage when i try and back up.
I dont know where I could have hit anything related to this in the install but does anyone have any insight into this? Did I blow a fuse maybe or is there a connection that I missed.
Old Jan 2, 2005 | 12:51 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The reverse switch is on the tranny itself. If that helps.
Old Jan 2, 2005 | 01:14 AM
quick99ls1's Avatar
quick99ls1
my reverse light switch on the tranny went out, doesnt cost much to get it fixed
Old Jan 2, 2005 | 12:59 PM
JC in XTC5's Avatar
JC in XTC5
The reverse lamp switch on the tranny fails - this is a common problem. Since it's on a separate fuse than the Approach Light circuit, the lights still come on when you hit the FOB.
The switch is on the passenger side of the tranny towards the top and screws out. When it fails, it tends to short and will blow the fuse so you'll need to replace that as well.
Old Jan 2, 2005 | 10:08 PM
dmoran1845's Avatar
dmoran1845
Everyone is correct. Just did mine about 2 weeks ago. The hardest part was trying to keep the dirt from falling in my eyes.
Old Jan 4, 2005 | 06:01 PM
FRC Rob's Avatar
FRC Rob
Same problem here...just replaced mine last week. A quick 5 minute fix, and since I got the switch for $12 at a local autoparts store, so I didn't have to take a hosing from the stealership's parts department!
To Reverse Lights
