I finally got around to doing my car and put in the lightened flywheel that I had matched balanced to my old flywheel. They drilled out 3 small spots on the flywheel and said that the pressure plate was pretty far off. They welded a weight about the size of 10 dimes stacked together on the pressure plate.
I finally put my car back together enough to start the car up (open manifolds ah yea). I was doing 3 things 1) visually check the pressure plate for any "wobble" which may have caused my slave cylinder to die
2) check for vibration and 3) heat up the motor oil to change it
Bad news to report is that there is vibration at around 2000 RPM's. Cruising RPM. Its not really that bad but its enough to be noticeable. I think I'm going to grind that weight off and hopefully it'll loose the vibration. I really wonder whats up with this, after taking the time and effort to get it match balanced and it vibrates. Ugh. I dont think the OEM assembly vibrated like this but honestly I cant remember.
Question that comes to mind is. Did you match the location of the weight to crank? If that weight was off position you will still have a Vibration. Just my .02
yeah I forgot to mention that- the flywheel has the little dimble where it only goes one way that matches the position on the crank. The pressure plate was paint marked to match the position. I even kept the bolts the same position.
Im going to cut that weight off and hope that it makes the vibration less, but theres a chance it may be more.
We put a new Z06 clutch in Sidestep's '01 a few weeks ago. We transferred the weights from the original flywheel to the new one. He had a slight vibration in it after trying it for a few days so he popped the weights out of the flywheel and the vibration was gone.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Cut the Weight
________________________________________ ____________________
Is it possible to cut a portion of the weight off ? Cut off maybe 1/3 of the weight and see if it gets better, or, worse
Well I cut the weight off and sure enough, it spins better. So much for match balancing. I'm STILL confused and havent found a definate answer yet.
Besides cutting the weights off, did you tranfer any press-in weights from your factory flywheel??? If so did you remove those (pres-ins) also when you cut the other weights off???
ah crap!.....does this mean I'm in for a balancing PITA when I install my new Exedy Twin clutch/flywheel setup? Do I need to get it balanced? or match balanced against my factory clutch assembly?
John
John
Wow, that really blows considering all the effort you put in to get it right. The only thing I can see that may have gone wrong is that you had the new flywheel balanced to the old flywheel rather than having the new PP and FW as a unit balanced to the old FW/PP unit.
I may be wrong but it sounds like things were spun separately.
Sorry to hear you are having a problem.. It really doesnt make sense to have a new assembly ballanced perfectly to the old one then have a new vibration? The only thing I could think of is... they didnt really ballance it to your old one.
Can you access the dowels through the acces cover on the bottom of the bellhousing?
I just swapped my clutch last week and I can feel the vibration at idle. Not horrible, but a little worse than it was stock. I am hoping I can press out the weights and see if it helps.
So can it be done without pulling the driveline again?
I just had my LUK pulled out due to vibration issues. It was 16 grams off. They are supposed to be balanced within 2 grams from the factory, I guess they have poor quality control.
The assembly was rebalanced and the vibrations are down, however they are not completely gone.
I am at the point where I am about to put a new engine in that is zero balanced so my vibration issues will be gone for good.
I didnt transfer any press in weights from the original flywheel. I'll post pics later of the weight that was "supposed" to balance out my clutch. I'm just glad the solution was as simple as cutting off the weight and grinding down the weld. My vibration was right at 1800 RPM, which is what the car runs at when doing 80 down the highway in 6th gear. I feel bad for all others who's car vibrate after installation.
Although the flywheel still was rebalanced, with 3 drill holes in the rear so this tells me something from the LUK assembly as still off.
Damn, this is all I needed to hear. My new motor is 0 balanced but there is a chance the LUK is not balanced? I just finished installing the motor yesterday! Uggggggggggg!!!!!!!!!!!!!!!!
My McLeod w/ aluminum flywheel was zero balanced from the factory and I have 0 vibration. I guess I got lucky there. I have had (3) Spec clutches, (1) on my former WS6, (1) on my C5 which was replaced because it was so out of balance, and the replacement vibrated at about 1800 to 2000 RPM.
