I am in the process of getting ready to do a cam package install. I am curious on how many of you also did the under drive pulley at the same time. I have heard that the under drive pulley is hard on the motor unless you spend over $500 for the pulley. Has anybody run into this situation?
I have an ASP on mine and no problems. I actually think the engine runs smoother with it than the stocker
I'm doing an ASP when I do my heads and cam. Good price too, 1/2 of what you think. Ditch the stocker before it comes apart, especially if you are taking it off to do the cam
Where did you get such a good price on the pulley?
Can anybody tell me if this ASP pulley has dampening built in? I think that is my concern on how tought it is on the motor if it does not have the dampening built in.
ATI here. Good enough for the World Challenge cars - good enough for me. Check out their site - good info.
I bought an MTI crank pulley but haven't installed it yet until I get the H/C ready to go. Anyone have any experiences and/or opinions about the difference between the ASP and MTI crank pulley?
Also, I wondered since I'm planning to install the Magnuson SC eventually if I should get the pulley drilled so I don't have to tear into that again later?
John
John
