How do I display an error code?
Old Jan 3, 2005 | 10:00 AM
pavesi's Avatar
pavesi
Default How do I display an error code?
My check engine light comes on about once a month for a few days and then goes off. How can I find out what the error code is so I can find out what is causing this light to come on? I have only had the car for 4 months and this is my first Vette. Any help would be much appreciated. Thanks in advance.
Old Jan 3, 2005 | 10:09 AM
Automag928's Avatar
Automag928
From the tech tips section:
The "diagnostic display" mode is entered with the following Procedure: Page 8-500
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10-Second period.
Initially, the on-board diagnostics go into the "automatic" mode, which shows each module's DTCs in a pre-set sequence: (Page No. are for the GM Service Manual)
* 10 PCNI Powertrain Control Module page 6-357 - 6-361
* 28 TCS Traction Control system ABS on page 5-86
* ?? RTD Real Time damping page 3-136
* 40 BCM Body Control Module page 8-405 LTD Page 8-727
* 60 [PC instrument Pane! Cluster page 8-508
* 80 radio page 8-213
* 99 FIVAC Heater Vent-Air Conditioning page 1-118
* A0 LDCM Left Door Control module page 8-904 to 8-951
* Al RDCM Right Door Control Module page 8-904 to 8-951
* AC SCM Seat Control module page 8-1064-8-1082
* B0 RFA Remote Function Actuation page 8-676
For each module, all DTCs will be displayed. If none are present in a module, you will see "no more codes" on the ICP display. There are two kinds of DTCs, "Current" and "History," designated with a letter suffix, "C" or "H". A current code indicates that the malfunction is present in the system whose module is displaying data. A history code indicates a problem existed in that module sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it is possible it's evidence of a previous problem. Now solved, that was not removed by clearing codes. More likely is that a history code indicates an intermittent malfunction.
"Intermittent" are the most challenging DTCs. An intermittent may have happened only once, may have happened more than once but is inconsistent in its appearance or may be happening on a regular basis but not at the time the IPC is displaying codes. History codes can also be caused by a current malfunction in a system that is not Operating at the time DTCs are displayed. An example is the rear window defogger, which doesn't operate until the BCM detects engine rpm. For history codes set by a system that does not operate with the key on and engine off, a special diagnostic tool called a "scan tester is necessary to properly diagnose the malfunction.
Once the IPC has displayed all 11 modules, the system goes into the manual mode, which allows selection of each module, using combinations of DIC buttons. The manual mode can also be entered at any time during the automatic sequence by pressing any button except "E/M". Once the IPC displays "manual diagnostics", you may select a particular module by pressing the options button to go forward or the "trip" button to go back. Once a system is selected and a DTC is displayed, if more than one are present; press "gages" To move forward or "fuel" to go back. To exit the diagnostic mode at any time, press E/M". If you want to erase or "clear" codes, press "reset". Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory.
Old Jan 3, 2005 | 12:59 PM
TeeJay's Avatar
TeeJay
It should also be noted that the diagnostics mode can be initiated while driving with <options> + 4X<fuel>. It's only distracting if you're on the phone at the time.
To How do I display an error code?
