Need predator help bad!!!!
Old Jan 4, 2005 | 08:08 PM
MassaRusty's Avatar
MassaRusty
Default Need predator help bad!!!!
I just tried to install the predator tune on my 2000 A4. I got a script error at the end of installing the performance tune. I then tried to reinstall the stock tune and got the same thing. I now have many codes and the check engine light is on. All of the codes are "H" codes, but there are quite a few of them. Do you think it is ok to drive the car and do you think it has the stock tune completely back in it?
Here are my codes
10 - PCM codes
P1518H
P1626H
28 - TCS
U1016H
60 - IPC
U1016H
U1664H
U1160H
U1040H
U1088H
U1176H
Any help would be greatly appreciated.
I also posted this in the scan and tune section, but I thought more people might see it here.
Old Jan 4, 2005 | 08:13 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
The codes are normal when programming. Relax clear the codes and just reinstall the performance tune again. Should work fine as this sometimes happens with the Predator.
Bob
Old Jan 4, 2005 | 09:07 PM
MassaRusty's Avatar
MassaRusty
Thank you, I got it to work this time. I didn't mess with any of the electronics or open the door the first time, but I didn't turn off the fan.
Old Jan 4, 2005 | 09:37 PM
16Again's Avatar
16Again
Good Job.
To Need predator help bad!!!!
