torque spec.
Old Jan 4, 2005 | 10:17 PM
Nuzz's Avatar
Nuzz
Default torque spec.
what is the torque spec. for the factory head bolts on a 2000c5?
thanks Nuzz!
Old Jan 4, 2005 | 10:46 PM
ragtopws6's Avatar
ragtopws6
Tighten the M11 cylinder head bolts (1-10) a first pass in sequence to 30 N·m (22 lb ft).
Tighten the M11 cylinder head bolts (1-10) a second pass in sequence to 90 degrees.
Tighten the M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence.
Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 N·m (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward, tightening all of the bolts.
Old Jan 4, 2005 | 11:03 PM
Nuzz's Avatar
Nuzz
thanks!
Old Jan 4, 2005 | 11:12 PM
Patches's Avatar
Patches
This will definitely help.
To torque spec.
