Next Performance Mod? Suggestions?
Old Jan 6, 2005 | 11:13 AM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Next Performance Mod? Suggestions?
I have an A4 2000 coupe, 3:15 gears with:
Blackwing
Dynatech long tubes w/ cats
Magnaflow cat back
Any suggestions for other performance mods under $1000? I want to stay away from major mods like heads/cam package.
Old Jan 6, 2005 | 11:24 AM
ragtopws6's Avatar
ragtopws6
Dollar for dollar your best bet is replacing the cam. If you do the work yourself you can do the cam upgrade (cam, hardened pushrods, valve springs and gaskets) for under $1000.00.
Old Jan 6, 2005 | 11:54 AM
chaase's Avatar
chaase
St. Jude Donor '12
Blackwing
Magnaflow cat back
Dyno-Tune (if you haven't already)
New rear-end gears (not sure if under $1000.0 or not)
Underdrive pulleys
Nitrous
Other than that I think you have to start breaking into the engine,
Chris
Old Jan 6, 2005 | 12:05 PM
C5JONNY's Avatar
C5JONNY
save up, do tc and gears.
Old Jan 6, 2005 | 01:39 PM
90 droptop's Avatar
90 droptop
It will transform your car. You can pick up a 3.42 rear and a used T/C off the forum and save a bunch. If you can do the install, your way ahead of the game. Then a simple retune and away you go.
To Next Performance Mod? Suggestions?
