the hell with this if the new poly bushings dont come with new inner shells, i been messin with just one stock bushing for an hour just to try to get the rubber off the metal tube. any ideas?
With Prothane and Energy, you reuse your stock sleeves. Do whatever you need to do to get your stock sleeves out. Hopefully you have a press, chisel, torch and lots of rage....it's supposed to be the worst thing ever, so if you get it done, go on vacation, you'll have earned it!
I am in the middle of it as well and it is the pits. Had that old ones pressed out and have been hacking on the old hardware for a few hours. Never again. Used a hack saw. Cut aound the circumference then ground the rest off with bench gringer.
VBP has all new hardware in their kit. We saved a couple bucks for this?
I did them to my previous car. I think the worst part was getting the old bushings out. Had to use everything from fire to hammers to saws to break them apart.
