resetting tire pressure sensor
Old Jan 8, 2005 | 11:47 AM
Rock0324's Avatar
Rock0324
Default resetting tire pressure sensor
In the past I have seen threads on how to reset tire pressure monitors. I had my LR one replaced at a neighborhood tire store, and after it was installed it didnt work. Do I need to reset it when I replace it, or is the replacement sensor defective. The other 3 are still reading out and working fine. The tire shop that replaced it is ordering me another sensor thinking thats the prob. Lesson learned when having work done on a Vet only go to a Vettech type shop. Anyone with an answer?
Old Jan 8, 2005 | 12:01 PM
Ls1Rat's Avatar
Ls1Rat
Reset It
Old Jan 8, 2005 | 12:18 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
CORVETTE TYRE SENSOR TRAINING
1) Turn ignition on
2) Press "Reset" button in order to clear any IPC display warning messages
3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank
4) Press and hold the DIC "Reset" button for 3 seconds
5) Press the "Options" button again until TIRE TRAINING message appears
6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming
7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do, like an old car speaker) over the left front valve stem
8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over)
9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear.
Tire Programming can be cancelled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is cancelled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
Old Jan 8, 2005 | 12:26 PM
Rock0324's Avatar
Rock0324
can I reset this myself, or do I need to bring it to the dealer? I dont see anything in the owners manuel. Is there a web site for me to go to?
Old Jan 8, 2005 | 12:30 PM
Rock0324's Avatar
Rock0324
thank you 12step I am going to give it a try
Old Jan 8, 2005 | 01:32 PM
servohead's Avatar
servohead
I've tried to reset mine and had no luck... Exactly how big of a magnet do you need?
Old Jan 8, 2005 | 03:11 PM
skip89's Avatar
skip89
A magnet off a stereo speaker will do it. Or ask a garage to follow the above directions
To resetting tire pressure sensor
