Going to paint engine covers need a little info
Old Jan 8, 2005 | 07:35 PM
scaperman's Avatar
scaperman
Default Going to paint engine covers need a little info
I got the paint the flex additive and hardner and reducer,I sanded the panels smooth already how many coats of paint should I apply and should I wet sand between coats? thanks
Old Jan 8, 2005 | 09:28 PM
USA-VET's Avatar
USA-VET
1 good primer coat
3 coats of paint
wet sand is a must
and dont forget the clear coat
Old Jan 8, 2005 | 10:26 PM
John Nowak PE's Avatar
John Nowak PE
You've already gotten some good advice on the paint.
The only thing I would add is to wash the panels with some TSP (TriSodium Phosphate). TSP is available at most hardware stores and it will clean off any residual oils and mold release agents that can mess up your paint job.
When I did ours, I also put a little extra clear coat on them (one extra coat). Then I wet-sanded with 2,000 grit paper and buffed to a high gloss.
Old Jan 8, 2005 | 11:16 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I used 3 coats of primer and 3 coats of color and 3 coats of clear
Old Jan 9, 2005 | 10:18 AM
scaperman's Avatar
scaperman
Should I wet sand between each coat of paint or after I got the three coats on?
Old Jan 9, 2005 | 11:35 AM
BSiegPaint's Avatar
BSiegPaint
If you are using a base coat / clear coat paint system, many manufacturers will tell you NOT to sand the color coats, only the clear. Check on the labels or product information sheets for the paint you are using. Good luck!
Old Jan 9, 2005 | 12:58 PM
screw991le's Avatar
screw991le
I did zero sanding. The primer is the most important. Have to get the color to stick to something. I used Krylon red primer, 4oz of GM paint #12345142 (sebring silver) and Krylon Crystal Clearcoat
To Going to paint engine covers need a little info
